AstroConnor
Jan 20, 2017Aspirant
R6300v2 Latest Firmware and no AP mode
I have a R6300v2 that I bought a few months ago that has the most current firmware (V1.0.4.6_10.0.76). I am trying to use it to connect my computer via ethernet to the modem in another room. The mode...
- Mar 02, 2017
Hi AstroConnor,
1. Is the R6300v2 connected to a plain modem or a modem-router combo?
2. If it is a modem-router combo, you can check page 100 of the user manual linked below to set it up in AP mode.
http://www.downloads.netgear.com/files/GDC/R6300V2/R6300v2_UM_20May2015.pdf?cid=wmt_netgear_organic
Dexter
Community Team
Jan 20, 2017Guru - Experienced User
Do you want to use the R6300v2 as a router or as an AP? Is the router's internet port connected to the modem, or one of the LAN ports?
AstroConnor
Mar 01, 2017Aspirant
I think AP. I just want it to be able to serve as an ethernet splitter honestly. There is another router connected to the same modem that works just fine for wifi. In its current settings, it seems to be amplifying minor ping spikes from the modem that are really effecting my gaming. The ping from the modem maxes at around 100ms and the ping from the R6300v2 maxes at 800, so there's quite the gap.
- DexterJBMar 02, 2017NETGEAR Moderator
Hi AstroConnor,
Dexter
Community Team
- DexterJBMar 05, 2017NETGEAR Moderator
Hi AstroConnor,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
