sweeney42002's avatar
sweeney42002
Follower
Jul 06, 2018
R6350 -ac1750 smart WiFi connection problems
I just purchased R6350 and having trouble getting wifi/and wired connection thru router working properly. I can connect a laptop computer directly to internet from provider and get 30mbps download/5mbps upload but when I connect a line thru router, I can't even get an upload speed to register. I downloaded app on my iphone and when I do a speedtest for wifi, I get nothing as well. The router has updated the firmware automatically and I have changed a few settings on router to try to fix problem but I am still having issues. Any suggestions or help would be greatly appreciated.
  • Hi sweeney42002,
    Welcome to the community!
    Please make sure that a factory reset is done after the firmware update and reconfigure the router. Please keep us posted if the issue persists.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi sweeney42002,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi sweeney42002,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
