dmp92996's avatar
dmp92996
Follower
Jun 16, 2017
R6400 and Computer setup
I just set up my new router today and it will connect to my phone but does not come up as a WIFI option on either my desktop computer nor my laptop computer. They both are using the original Verizon ...
  • DexterJB's avatar
    Jun 20, 2017
    Hi dmp92996,
    1. Are the 2.4GHz and 5GHz LED's lit on the router?
    2. You can try resetting the router to factory defaults.
    3. If the issue persists, you can try changing the wireless channels.
    Dexter
    Community Team
