Help
4 TopicsCannot access my router settings (log-in) in any way (factory reset'd several times)
Hey everyone, before I start I want to apologize if this is not the correct section to post this thread. The router I currently own is this one (click here) and I simply cannot access my router settings (routerlogin.com or 192.168.1.1) I do get the text box to input my username : password but all the login infos I've looked up in google won't work. Text Box I get to see. I tried multiple sites to check for login info and none work, one of those being this huge "2018 updated" list: https://www.lifewire.com/netgear-default-password-list-2619154 At the beggining I thought it could be my router messing stuff around because sometimes I got a message saying "Your conenction is not secure" so I tried on MS Edge and then on Firefox, no luck either. I decided to contact ISP, blah, blah, for security reasons they cannot give me admin : password (not sure why?) [My ISP provided me this Netgeat router, I didn't buy it by myself]. Anyhow I did not care about what they said because I used to have TrendNET router and could access to my router settings with no interference from them; the next big step I did was holding the little "factory reset" until the power light started to blink (Not sure if it's held more time it might do something). After factory reset I got the default SSID and PW of the network, I logged in, and had to "log-in" to the network, the only thing it said was the SSID and PW I already knew and 2 buttons, one was to print all the info and the other one to proceed and "activate" the internet. Tried all the possible combinations of admin : password after factory reset and no luck either, no I'm stuck with a SSID called "SureWest-f1" instead of the custom SSID I want. I remember once after a while (because I gave up and submitting a live chat here required a proof of purchase which I don't have because like I mentioned before, my ISP gave this to me) I remember attempting to factory reset it again like 4+ times, and only ONE of them allowed me to access the router info, I had like 3 options to choose, continue with net, configure settings, etc. (instead of the print thing screen I mentioned before) but amazingly unlucky me something happened and after settings everything I wanted, the save button or whatever it was simply didn't work, didn't have connection anymore, had to factory reset again and since then I haven't ever been able to access my router settings apart from that lucky try. (Not exactly sure WHAT I did that one time, maybe I held the factory reset button longer? Who knows..) I'd really like to access my router settings to change SSID how I want, custom password, and doing some port-forwarding. Please any help is appreciated, my ISP just won't help me, they're limiting me what to do with my OWN router.SolvedR6400 Networking speeds
I bought this router 1 week ago sadly since I started using it I've had lots of lag spikes and packet loss whenever I game or when I stream Netflix on my TV connected through the ethernet cable and I dont know how to fix it. ive tried to reset my router, the typical turning it on and off and copying the settings from my last router and it doesnt seem to work at all, it also happen that when I do a speedtest, it gives speeds of 200Mbps+ download, and average 150Mbps upload, but suddenly in the next test just after the first one, it just gives up to 10Mbps, but the uploads still over the 100Mbps, it really fluctuates a lot, so I don't know what's happening. Btw, I have the last firmware version: V1.0.1.20_1.0.16.Solved5.4KViews0likes2Comments
