pau11y
Mar 17, 2018Aspirant
R6400 readyshare stopped working
We've been using a seagate ext hdd for over a year (maybe two years?) via the back usb port as a readyshare drive. Had worked without troubles on wife's work computer (work's from home, win10) from d...
- Mar 19, 2018
Hi pau11y,
1. Please make sure that you have done a factory reset after the firmware update.
2. Does the issue persist when using a different storage device (another HDD, flash drive)?
3. Does the issue persist when using the other USB port?
4. Does the USB LED still light up if the issue occurs?
5. Does the issue persist on your other devices?
Dex
djhurlburt
Apr 17, 2018Apprentice
I have the same issue. I've done a factory reset and have tried multiple usb drives. IThe lights are flashing and I can see the usb drive when I go into routerlogin.net and go into "ReadySHARE". I created an "Available Network Folder" and it forces the "U" drive to be set. However if I go into WIndows explorer and type "\\readyshare" it can't be reached.
Going into the horrible Netgear Genie App, if I go to ReadyShare, it doesn't see the drive --- it tells me that I need to plug in a drive..even though it is lit up and accessible through routerlogin.
DexterJB
Apr 18, 2018NETGEAR Moderator
Hi djhurlburt,
Welcome to the community!
1. What is the firmware version of the router?
2. What is the Windows version of the computer?
3. Was it working before?
4. If you are using Windows 10, the links below may help out:
Dexter
Community Team
- DexterJBApr 23, 2018NETGEAR Moderator
Hi djhurlburt,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team - djhurlburtApr 23, 2018Apprentice
Router firmware: V1.0.1.36_1.0.25
Operating System: Windows 10 64bit
Working before: yes - about 3-5 mo ago
Hyperlink provided: I tried that before posting to the community; it did not work.
- schumakuApr 24, 2018Guru - Experienced User
djhurlburt wrote:Operating System: Windows 10 64bit Working before: yes - about 3-5 mo ago
About the time Microsoft started to remove the CIFS/SMB 1.0 feature if it was not used for a while.
Have the CIFS/SMB 1.0 Client feature installed and enabled on your WIndows 10 system? And the CIFS/SMB 1.0 Automatic Removal feature disabled to avoid the unexpected?
- djhurlburtApr 25, 2018Apprentice
From my read, the SMBv1 needs to be disabled; here is a screen shot of my system's features:
