pau11y
Mar 17, 2018Aspirant
R6400 readyshare stopped working
We've been using a seagate ext hdd for over a year (maybe two years?) via the back usb port as a readyshare drive. Had worked without troubles on wife's work computer (work's from home, win10) from d...
- Mar 20, 2018
Hi pau11y,
1. Please make sure that you have done a factory reset after the firmware update.
2. Does the issue persist when using a different storage device (another HDD, flash drive)?
3. Does the issue persist when using the other USB port?
4. Does the USB LED still light up if the issue occurs?
5. Does the issue persist on your other devices?
Dex
djhurlburt
Jul 02, 2018Apprentice
if I type in "\\192.168.1.1" I get:
Your file was not found
It may have been moved or deleted.
ERR_FILE_NOT_FOUND
michaelkenward
Jul 02, 2018Guru - Experienced User
ERR_FILE_NOT_FOUND
Is that before or after you get asked for the password?
- djhurlburtJul 02, 2018ApprenticeIt never prompted me for one.
- michaelkenwardJul 02, 2018Guru - Experienced User
It should ask you for the login details for your router. It does here.
