Mph3842
Nov 19, 2021Aspirant
R6400 used as a switch, not as a router
I just got T- Mobile 5g internet and I am using the wifi signal from it. I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via ethernet to the T mobile router. Is there a way that I can still use the Readyshare in the Nighthawk in order to use the USB port on the Nighthawk as a netowrk drive? Thanks in advance.
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
Mph3842 wrote:
I want to use my Nighthawk router as a switch so I turned off the wifi on the Nighthawk and connected the router (switch) via ethernet to the T mobile router.You could turn the R6400 into a wireless access point. Then just turn the wifi off with the switch on the top.
Is there a way that I can still use the Readyshare in the Nighthawk in order to use the USB port on the Nighthawk as a network drive?I see no sign that AP mode disables ReadySHARE.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But you'll have to try it.
Is this related to the issue you asked about six months ago?
I have an R6400 and want to connect a HDD via USB ... - NETGEAR Communities
PS There really was no need to waste anyone'e time by going to a different section to deal with this issue. The question is generic and the answer would be the same for the Nighthawk section as it is for this one.
- Mph3842Aspirant
Yes it is the same issue. I tried the AP setting and it did not work. Thanks for your help.
