afterglow727
Jan 12, 2023Aspirant
[R6400] Wired Works, Wireless drops out frequently during day
I've got an R6400 handling wired and wireless networking in my small apartment.
Always once a day, sometimes twice a day, all wireless devices will lose wireless internet connectivity, and I will need to restart my router to restore wireless networking. I've noticed that while my wireless will fail, my wired networking is still working perfectly. (which to me indicates that the general internet service and modem are fine).
Wired, I have 2 PCs.
Wireless, I have a phone, a tablet, a laptop, 2 Sonos speakers, an Apple HomePod mini (which *should* coordinate a dozen smart bulbs on Thread).
Router firmware: V1.0.4.128_10.0.104
What could be the cause of the issue, and how can I troubleshoot and remedy this?
Thanks!
Jake
That firmware is for the R6400 V2.
What symptoms do you see? Do the WiFi router's LEDs go off?
The first thing to try is a factory reset followed by a fresh setup.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front. It is also the first thing that Netgear support will recommend.
- afterglow727Aspirant
michaelkenward wrote:That firmware is for the R6400 V2.
Ah yes, that is correct. I have an R6400v2, not an R6400.
michaelkenward wrote:What symptoms do you see? Do the WiFi router's LEDs go off?
Symptom-wise, my devices still maintain their connection to the wireless network when the trouble begins, but they'll cease connecting through to the internet (and will complain "[WiFi Network] doesn't appear to be connected to the internet, keep trying?"). If memory serves, the LEDs don't indicate there is a problem. I will double check this.
I'll do a factory reset and setup, note the LEDs when all is working, and compare to the LEDs when it fails. (And if it doesn't fail, then case closed!).
Thank you!
Sorry for the delay - I've given the router a few days to see how it behaves.
I performed the factory reset, made sure it had the latest firmware, and used it as-is with no other changes.
I noticed the same behavior: after some amount of time, the wireless network would fail (no connectivity, or sometimes minimal activity with significant packet loss) all while the wired network worked at full capacity.
The LEDs showed no change between a fully functional state and a failing wireless state.
Restarting the router, as before, served as a temporary fix until the wireless failed again later.
Did anyone have any thoughts on this issue?
I am still experiencing consistent drop outs of the wireless network.
Thank you!
- chamaneaAspirant
Hi, having the same issue with my R6400 V2, did you end-up finding a solution to your wifi disconnection issue ?
I somewhat found a solution.
I found there were a lot of wireless networks in my area (using some free wifi-detecting apps), so I manually set my wireless channel to one with the least interference from nearby networks.
This helped substantially -- I would go maybe 2 or 3 weeks without needing to reboot my router.
Not perfect, but a big help.
I've since moved to an area with much less interference, and have not had to reboot it at all.
I'm not sure why rebooting would be the solution to interference -- but it seemed like general interference was the culprit.
