ITmouse
Jul 11, 2022Aspirant
R6400v2 — AC1750 Smart WiFi - Can't Connect to Work
A couple of weeks ago I switched ISP and also got a new wireless router. The previous router was supplied by AT&T.
Internet works great with the new router and ISP. Biggest issue, I cannot remote into work. I cannot connect to my work vpn (work firewall). I thought it was just a vpn issue, then I realized that my security camera app on my phone will not connect either. They both connect to my work firewall. I now use the same ISP at home and work. Prior to that they were different companies. I called the current ISP and they said it is my router setup but I can't find anything that is blocking this connection. I can connect via hotspot from my phone, so I know it is not my work firewall issue. Any suggestions or fix?
Thanks
What current modem/gateway do you have the R6400 connected to?
- ITmouseAspirant
The ISP supply the media converter from fiber to cat5 connector. (Don't know the device name or model. Will have to check that when I get home from work). The R6400 is the router and wifi. I cannot remember the gateway settings, since I use the netgear auto internet setup and it use the dhcp settings from the ISP.
