drewcook502
Dec 25, 2022Aspirant
R6400v2 erasing logs on restart
Hello,
I am running into an issue were every three to four days I have to restart my netgear R6400v2 (firmware version V1.0.4.128_10.0.104) in order to connect anything. I'd like to troubleshoot this issue but every time I restart the router, it erases its logs. How do I get the logs to persist across restarts? If this isn't possible, is there any other way I can access the logs when the router refuses all current and new connections (both wifi and ethernet)?
drewcook502 wrote:
Hello,
What happens that forces you to restart the router?
Connections from what? What happens?
It might help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting. And the symptoms you describe could be down to something else on the network, such as a modem/router.
... every time I restart the router, it erases its logs.
That's a bit odd. Could be something related to the other behaviour.
I'd start by trying to sort out the refused connections rather than the lost logs.
- drewcook502AspirantI restart the router as a general tech support trick (restart each possible device that could be the cause of the problem).
When I say it refuses connection, I mean I can see the SSDIs but selecting either does not result in connection. Most of the devices it just attempts to connect several times before quiting. Cell phones display a ip configure error but with no other information. No other device show any error messages.
The modem is a netgear cm500. Restarting it, while keeping the router on, does not fix the issue, only restarting the router does so I'm fairly sure it's something with the router.- michaelkenwardGuru - Experienced User
drewcook502 wrote:
I restart the router as a general tech support trick (restart each possible device that could be the cause of the problem).There's another general support trick for routers, return it to default settings and set it up from scratch.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset.
Do it when your router is behaving normally and you can access the browser graphical user interface (GUI).
With luck, your problem will go away after the reset.
You could then try restoring the settings, but be prepared for that to bring back your problem. At least you would then know that the reset fixed it.If the reset didn't fix the problem, you can restore the settings.
