rgjacobsen
Feb 13, 2022Tutor
R6400v2 Router keeps dropping Internet Connection
R6400v2 Router keeps dropping Internet connection. Some days I have to reboot it twice or more. Weirdly enough, checking the Internet connection through the app always gives me the super fast connection result, even when the browser can’t work and the Nighthawk app says it’s offline.
1. what firmware is on the router?
2. what modem/gateway is it connected to?
3. did this just start? has it been going on a while?
4. does it happen to all devices? Just wireless devices? Just wired?
5. Is IPv6 enabled? (if not enable and reboot the router)
- It has the latest firmware version. I think this started after I installed it. The modem is an Arris SB6190, but if checking the Internet speed through the router’s app works, then I doubt it’s the modem. It also gets temporarily fixed after rebooting the router. I haven’t checked the wired devices, but all the wireless except TVs on Roku seem to get affected. IPv6 apparently comes disabled by default, I have just enabled it and set to use DHCP.
"The latest version" isn't always the latest or there could be a version with issues. Its why we ask for an actual version number you're on.
did ipv6 help?
