ldjessup
Nov 24, 2017Aspirant
R6400V2 WPS button location
Trying to use wps. The manual states to use wps use the button on the back. There is NO wps button on the back.... So how do I activate wps or what is the alternative? Thanks
- Nov 25, 2017
Page 114 in the manual was the answer. Log in to the router, go to advanced setup, click on next, wps!
Thanks
michaelkenward
Nov 25, 2017Guru - Experienced User
Remember, the WPS "button" is one of those dual-purpose things that looks like the rest of the lights on the device. You would not be the first person to miss that subtle design feature.
Press the WPS LED.
You can also start the process in the software interface.
There is a manual for the R6400v2 somewhere at the end of this link:
>>>> R6400v2 | Product | Support | NETGEAR <<<<
See page 114.
- ldjessupNov 25, 2017Aspirant
Thanks
- michaelkenwardNov 25, 2017Guru - Experienced User
No "button" on the top?
