GreyBeard1948's avatar
Apr 08, 2021
Rbr50 and two satellites
Whenever I try to see if there are any firmware updates I get an error message instead of the message stating your firmware is up to date. Any suggestions as to why I keep getting the error message. I think I am up to date but am not sure now.
  • plemans's avatar
    what modem/gateway do you have?
    What actual firmware version are you on?
    You can view/download the latest firmware on the support site.
    https://www.netgear.com/support/product/RBR50
    the manual walks you through manually updating as well. If you go this route, do the satellites first.
    • GreyBeard1948's avatar
      GreyBeard1948
      The router firmware is v2.7.2.104
      I am not sure what you mean about modem/ gateway but we use point broadband as our internet provider as we stream our television viewing. One of the satellites is the Rbs 40v Orbi voice. I am not sure if that would cause the error message all the time.
      • plemans's avatar
        You are up to date (as of today) but it might not be connecting to the server properly if  you have a double nat issue.
        It why i was curious about your modem/gateway
