Gibbous
Oct 28, 2020Tutor
RBW30 Latest Firmware file corrupt
RBW30 Latest Firmware file corrupt!! 2.6.1.6
Broken .chk file instead of upgrade image.
It can be a .chk file or .img file.
- GibbousTutor
Oops... thank you.
Having the same issue with the download on my imac the file shows up as "Adobe"icon am unable to get the zip file for the Satellite RBW30. The same goes for RBR40 getting the dmg file and it will not open.
In retrospect I would never buy anything from Netgear again even tho everything works great it's always the problems in trying to update. In the Orbi App says everything is "up to date while on line it shows new firmware:.
Sorry to see Apple leave the router business.
RBW30 finally updated in the app on my IOS, took a lot of attempts and the funny thing was not trying when it updated. Still not updating on the RBR40
- indygadgetguyAspirant
Sorry, I'm not able to upload the .chk file. The GUI says the firmware must be an .img file.
> [...] I'm not able to upload the .chk file. The GUI says the firmware
> must be an .img file.Did you read any of the material above in this old thread which you
have (inappropriately) joined? Which part of the following was
unclear?:[...] starting your own new thread for your own problem is usually
a better idea than joining an old thread which has been marked as
"Solved".And which part of the paragraph which began as follows was unclear?:
"unable" is not a useful problem description. [...]
_Which_ "the .chk file"? To what were you trying to upload it?
