Sakikitty's avatar
Sakikitty
Follower
Sep 12, 2017
Reboots randomly R6300v2
I got my router a week ago and so far it's randomly reboot itself about 5 times. Sometimes a few times a day sometimes not at all. Any help?
  • Hi Sakikitty,
    1. What is the firmware version of the router?
    2. Have you tried resetting the router?
    3. Have you tried switching to a different power outlet?
    4. Are you using the power adapter that came with the router?
    5. Have you tried using another power adapter with the same specs as the one that came with the device?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Sakikitty,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Sakikitty,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
