guyinsb
Jun 30, 2025Aspirant
Registration is required
It appears that registration is required in order to configure the router (to change the SSID, for example).
Physical access to the device is required to change the SSID. Registration is not.
Perform a Factory Reset on the device and configure it. One step in the process is to change the WiFi SSID/password (if desired)
- guyinsbAspirant
Here is my experience. After a Factory Reset, I connected (via an Ethernet cable to a LAN port) to a Netgear R6400 (pre-owned, purchased from eBay) using a browser directed to 192.168.1.1. I encountered a screen requiring me to register. My attempt to register failed, because the router had been registered by a previous owner.
My experience with Netgear routers has been that every time I perform a configuration, the "Register this device" screen pops up and I simply ignore it and go on to the next screen.
It might be useful to examine that screen carefully.
Best done with a wired connection, a web browser and the graphical user interface (GUI).
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
Then:
How do I change my NETGEAR router password or network name (SSID)? - NETGEAR Support
Just another user with time on their hands.
