Carl47's avatar
Carl47
Remote Access
Router setup has an option for remote access, but this router is not supported by Network Genie, so how do I access it remotely?
  • Carl47's avatar
    Carl47
    Oct 28, 2018
    Yes, the model is accurate.  And, I managed to figure it out even though searching the Netgear site wasn't helpful this afternoon.
    For any who need to remotely control this model,
    1. Enter https://WANIP:PortNumber into your browser
    2. Login
    3. Netgear genie will open and you'll be able to reboot your router from anywhere.
    4.  Unfortunately, you'll have to  turn off your VPN if you use one.
  • > Model: WNDR4300|N750 Wireless Dual Band Gigabit Router
       Is that accurate?  (Not a WNDR4300v2?)  Firmware version?
    > [...] how do I access it remotely?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Remote Management".
    Further reading might also be helpful.
    • Carl47's avatar
      Carl47
      2. Login
      • antinode's avatar
        antinode
        Guru
        > [...] I managed to figure it out [...]
        > For any who need to remotely control this model, [...]
          In other words, you followed the instructions in the User Manual?
