Andy883
Feb 14, 2023Aspirant
Reset netgear email account
Hi, I no longer have access to my email address and obviously cannot access my Netgear account. Can this be reset if I prove ownership of the account and how can that be done? Thanks.
hanbisemo
Mar 16, 2023Aspirant
So I have a netgear Nighthawk router and i have no idea what the login is, and the person who made the login recently passed away, so I have no idea how to contact metgear to get it changed because they don't appear to have a tech support number. How do I get in contact with them and change the login details, is it even possible without the email of the person who set it?
- michaelkenwardMar 16, 2023Guru - Experienced User
hanbisemo wrote:
So I have a netgear Nighthawk router and i have no idea what the login is...
Login for what? The router and its browser graphical user interface (GUI)?
You do not need any login account to use that on your Netgear router
If you have don't know the login details for the GUI, Netgear cannot help you. It is encrypted and buried inside your router.
If you are trying to access this unnamed device. try the default settings on the label. If that fails, then simply reset the router and set it up from scratch.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
If that isn't the thing you are trying to access, tell us what it is and some may have other thoughts.
