djordje007
Nov 14, 2018Aspirant
Router does not show windows network computers but has internet connection!
I work in the office where LAN network and internet access are used through LAN cable. The LAN adapter settings are following in order for network and internet to work: IPv4: IP adress: 192.168.157....
- Nov 15, 2018
djordje007 wrote:
Please if someone can help with this problem.- Turn JWNR2010v3 into access point (see manual)
- Plug JWNR2010v3 into router
- Plug PC into JWNR2010v3
Or
- Get small ethernet switch (four ports is probably smallest you can get)
- Plug JWNR2010v3 into switch
- Plug PC into switch
The network's router, whatever that is, will handle all the addressing, JWNR2010v3, PC and anything that connects to the wifi.
djordje007 wrote:
In my opinion it has to do with Router giving the right IP adress to PC (so PC can use IP settings that work).Not really. You already have a router at the other end of your LAN cable that is handling IP addresses. It is unwise to have two routers trying to do that.
djordje007
Fotgot to mention: router gives PC following IP adress: 192.168.199.2.
