djordje007's avatar
djordje007
Router does not show windows network computers but has internet connection!
I work in the office where LAN network and internet access are used through LAN cable. The LAN adapter settings are following in order for network and internet to work: IPv4: IP adress: 192.168.157....
  • michaelkenward's avatar
    michaelkenward
    Nov 15, 2018
    djordje007 wrote:
    Please if someone can help with this problem.
    • Turn JWNR2010v3 into access point (see manual)
    • Plug JWNR2010v3 into router
    • Plug PC into JWNR2010v3
    Or
    • Get small ethernet switch (four ports is probably smallest you can get)
    • Plug JWNR2010v3 into switch
    • Plug PC into switch
    The network's router, whatever that is, will handle all the addressing, JWNR2010v3, PC and anything that connects to the wifi.
    djordje007 wrote:
    In my opinion it has to do with Router giving the right IP adress to PC (so PC can use IP settings that work).
    Not really. You already have a router at the other end of your LAN cable that is handling IP addresses. It is unwise to have two routers trying to do that.
