djordje007
Nov 14, 2018Aspirant
Router does not show windows network computers but has internet connection!
I work in the office where LAN network and internet access are used through LAN cable. The LAN adapter settings are following in order for network and internet to work: IPv4: IP adress: 192.168.157....
- Nov 15, 2018
djordje007 wrote:
Please if someone can help with this problem.- Turn JWNR2010v3 into access point (see manual)
- Plug JWNR2010v3 into router
- Plug PC into JWNR2010v3
Or
- Get small ethernet switch (four ports is probably smallest you can get)
- Plug JWNR2010v3 into switch
- Plug PC into switch
The network's router, whatever that is, will handle all the addressing, JWNR2010v3, PC and anything that connects to the wifi.
djordje007 wrote:
In my opinion it has to do with Router giving the right IP adress to PC (so PC can use IP settings that work).Not really. You already have a router at the other end of your LAN cable that is handling IP addresses. It is unwise to have two routers trying to do that.
djordje007
Nov 15, 2018Aspirant
I want to install WiFi in my office but not lose connection with LAN network computers. I realize the router is old, but there should be a way for PC to see other LAN network computers through Netgear router. I listed the adapter parameters that my network accepts, router also accepts, but with losing LAN network connectivity.
michaelkenward
Nov 15, 2018Guru - Experienced User
Once again, not knowing what this N300 device is that you want to add, it is anyone's guess as to how you do it.
If it is the JWNR2010v3, then we need to know what the router is that you want it to talk to.
The way to achieve what you want is probably to use the N300, whatever it is, as a wireless access point. In that way the unnamed router picks up the task of handing IP addresses. You shouldn't need to do anything with the "N300" on that front.
The JWNR2010v3 is old and does not seem to have a manual of its own, but it is a generic box that may well have the same settings as others in the same range.
>>>> JNR1010v2 | N150 Wireless Router | NETGEAR Support <<<<
Check the section Wireless Distribution System. Look at the bit Wireless base station.
