Mdavis19
Dec 14, 2020Aspirant
router drops
My router drops the internet connection 2 times a day. The reboot ALWAYS gets it back up, but then the next day or two, it drops again and I have to do a reboot.
As usual I always get the response
DHCP enabled. Waiting for DHCP to complete...
Testing Gateway
The gateway is invalid
Cannot test DNS
The router internet port as no connection or te connection is loose, or the conn...
Reboot router??
Which I do. How can I get this to stop doing this and I have to reboot every few days to fix this.
the support link i added prior? it has the firmware where you can download it. It also includes a manual that goes over manual firmware update process.
What router do you have?
What firmware is on the router?
What modem/gateway is it connected to?
- Mdavis19AspirantSorry. It connects to a arris surfboard docsis 3.1 by ethernet port . ISP is xfinity. I am not using their modem.
- Mdavis19AspirantA7000 ac1900
The latest firmware. It shows i don't have anymore updates from firmware 1 0 9 88.- plemansGuru - Experienced User
A7000 is a wireless usb device.
the firmware indicates its a R7000 router. And that its not on the latest firmware.
I'd try upgrading the firmware over a hardwired connection, then factory reset, and do a clean install (not from backup).
https://www.netgear.com/support/product/R7000
Also, Arris makes many modems. and some modem/router combo devices. What specific one do you have?
- Mdavis19AspirantI have an T25 Arris surfboard docsis 3.1 cable modem for xfinity internet and voice .
It keeps telling me my firmware is up to date. How can I force another upgrade if it won't prompt me?
