WinstonJEC
Feb 22, 2018Tutor
Router speed does not match Modem
Hi,
I'm having an issue with my R6100 router. It's not matching my ISP speeds like my modem does. If I plug my PC directly into my modem I pull 100+ mbp/s down every time. As soon as I direct plug into my router I drop to about 60 mbp/s. The R6100 is more than capable of handling 100+ mbps/ so I know that the router itself is not the issue. I contacted the ISP and there is nothing they can do on their end since it's coming from the router. I've already tried downloading the newest firmware and factory reseting the router. Nothing has worked and I can't stand to keep unplugging and plugging in my modem directly and lose wifi. Please help!
You may find this hard to believe, I do, but there is a 100 Mbps limit on the LAN speed of the R6100.
According to the manual it does:
LAN 10BASE-T or 100BASE-Tx, RJ-45
WAN 10BASE-T or 100BASE-Tx, RJ-45
This does not explain the speed loss you see – although you have to remember that the 100 Mbps covers everything that is going on on your network – but it does mean that you will never get the same speeds as devices that do 1000BASE-Tx. I didn't realise that Netgear still made 100BASE-Tx stuff.
I know my router is older but I didn't realize that it didn't have gigabit ethernet, but I am also confused nonetheless why it's dropping 40 mbp/s since it "supports" 100. I've ordered a N750 which I know definitely supports it so I will be testing my internet speeds on Sunday to verify. I will follow up and let you know if that fixes my issue. Thank you very much!
Who knows what it will do for your LAN speeds?
By the way, there is no such thing as an "N750". That is a label that Netgear uses to boast about the wifi speed of its hardware. N750 is also pretty old and slow.
