orcslaya's avatar
orcslaya
Follower
Jul 24, 2021
Routers that support Remote Management
Below shows the list of AC router that supports Remote management or anywhere access. I am posting this after a lot of confusion on whether the R6120 supported this feature or not (It does NOT). Hope this helps other going forward:
AC2400
R6260
R6350
R6700
R6700v2
R6700v3
R6800
R6850
R6900
R6900P
R7000
R7000P
R7800
R7850
R7900
R7900P
R8000
R8000P
R8300
R8500
R8900
R9000
RS400
  • schumaku's avatar
    schumaku
    The AC1200 WiFi Router Model R6120 User Manual as well as the AC1200 Dual Band WiFi Router R6120 Data Sheet do neither list the classic IP based Remote Administration/Remote Management nor the Nightgear App Based Anywhere Access to be available (the way I'm reading the docs), indeed.
    A lot of confusion in these designations indeed. Because Netgear used the terms Remote Administration _and_ Remote Management for the direct based access using a Web browser, the App based access used to be under the subject "Remotely Access Your Router Using the genie App" (e.g. in the R9000 User Manual) for the Netgear Genie App resp. "Connect to your router with Anywhere Access" for the Netgear Nighthawk App as well as for the Netgear Orbi App (depends on the product of course).
    FMI (with the about "current" list of products where the feature applies to ... always best effort):
    Remote Management is now Anywhere Access in the Nighthawk and Orbi apps
    How do I enable or disable Anywhere Access on my router using the Nighthawk app?
    How do I enable or disable Anywhere Access on my Orbi router?
    In brief, for "Manage Remote Access"
    You can access your router over the Internet to view or change its settings. You must
    know the router’s WAN IP address to use this feature.
    Note: Be sure to change the password for the user name admin to a secure password.
    The ideal password contains no dictionary words from any language and contains
    uppercase and lowercase letters, numbers, and symbols. It can be up to 30 characters.
    See Change the admin password on page 95.
    Set up remote management
    To set up remote management:
    1. Launch a web browser from a computer or mobile device that is connected to the
    router network.
    2. Enter http://www.routerlogin.net.
    A login window opens.
    3. Enter the router admin user name and password.
    The user name is admin. The password is the one that you specified the first time
    that you logged in. The user name and password are case-sensitive.
    The BASIC Home page displays.
    4. Select ADVANCED > Advanced Setup > Remote Management.
    The Remote Management page displays.
    5. Select the Turn Remote Management On check box
    Use Remote Access
    To use remote access:
    1. Launch a web browser on a computer that is not on your home network.
    2. Type your router’s WAN IP address into your browser’s address or location field followed by a colon (:)
    and the custom port number.
    For example, if your external address is 134.177.0.123 and you use port number 8443, enter
    http://134.177.0.123:8443 in your browser.
    In brief, for Anywhere Access:
    The Anywhere Access feature on the Nighthawk app allows you to connect to your
    router when you're away from home and change its settings. Before you can use the
    Anywhere Access feature on the Nighthawk app, you must update your router’s firmware
    and download the latest Nighthawk app for your mobile device.
    So two complete different features in fact!
  • michaelkenward's avatar
    michaelkenward
    Not quite a complete list:
    Model R6050
    R6100
    R6200
    R6220
    R6230
    R6250
    all include "Remote Management" in their manuals.
    There may be more!
    It is a pity that Netgear does not provide this infomation.
