molaver's avatar
molaver
Tutor
Nov 30, 2021
Should I do a factory reset?
I recently changed internet providers from Comcast at 75mbps to 1 Gig 5G fiber optic.  Wifi properties of the Netgear router (shown on my laptop) list the link speeds at 866 receive and 433 transmit.  However, using the Nighthawk app's "speed test", I am seeing 240-290mbps download speed and 650-700mbps upload speed.  This does not seem right to me.  Shouldn't download speed be faster than upload?  Could there be some residual issues in the router from the change in providers?  I did not reset the router prior to the change.  Just turned off, unplugged, reconnected with the new Cat 6 cable, plugged in and turned on the router.  If that was all that needed to be done, what other issues should I be looking at ???
  • There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/product/R6220.aspx
    Its a great resource to start with for finding those settings.
    You can access the routers setting through your browser pretty easily.
    Or you could just factory reset it and start back at square 1. Never a bad idea when switching isp's or changing speed.
  • plemans's avatar
    The R6220 is a very base model gigabit device. A couple things.
    1. you won't see gigabit speeds over wireless.
    2. link speeds are roughly 55-65% of throughput. Meaning if you actually connect at 866mbps, you're actual throughput is only going to be 55-65% of that for 5ghz. 2.4ghz is even worse
    3. 2.4ghz is a slow network. its throughput is even lower because of the very nature of how it works.
    4. When you test off the built in speedtest, it hosts the test off the router. this isn't always the most accurate as it rarely chooses the best server.
    5. With the r6220 being very base model, if you're using any extra monitoring like qos, access control, traffic monitoring, or parental controls, your speeds will drop to what you're experiencing. Its because then the router has to inspect the traffic and its doesn't have enough processor power to do so at gigabit speeds.
    so heres where I'd start.
    1. disable qos, access control, traffic monitoring, parental controls. Then reboot your device.
    2. hardwire a pc/laptop into the router and test off the hardwired device. Not the built in speedtest. try different test servers as when you get to gigabit speeds, some test servers wont' max out gigabit
    Try that first and see what you get.
    What modem/ont are you connecting to?
    • molaver's avatar
      molaver
      Tutor
      Thank you for the quick reply.  Not sure where to look for qos, access control, traffic monitoring, parental controls.  I went to the administration page of my router and only found a traffic metering setting which was set to off.  Are the settings you mentioned found on the router or the laptop?  After establishing these things, I can then do the hard wire from the router to the laptop and report the results.  The modem (ONT) I am using was supplied by the ISP which they remotely tested and claimed is functioning properly at 1 gig speed.  Although the provider's tech support only addresses issues with their hardware, they did mention that there might be an issue with a firewall.  I poked around and found firewall settings but nothing that looked like it pertained to the router or internet settings so I left everything alone.  I apologize for needing a bit (or a lot) of hand holding...wifi/networking issues are not my strong point.
      • plemans's avatar
