Lancelotdb's avatar
Aug 07, 2023
[Site blocked: tlu.dl.delivery.mp.microsoft.com] from source 192.168.1.23
Hello,
The logs regularly indicate that the router is blocking a Microsoft update.
After several requests, the router goes into protection mode and the Internet is no longer available.
How can I fix this?
Many thanks
Lancelot Db
Bonjour,
Les logs indiquent régulièrement un blocage par le routeur d'une mise à jour de Microsoft.
Après plusieurs requêtes le routeur se met en protection et l'internet n'est plus disponible.
Comment fixer cela?
Un grand merci
Lancelot Db
    • Lancelotdb's avatar
      Lancelotdb
      Tutor
      Thank you for your help.
      I have the R6400v2 router firmware V1.0.4.128_10.0.104.
      I have the Nighthawk application but I can't connect to it from my phone using the login and password which works from my PC with the url http://www.routerlogin.net/start.htm
      • michaelkenward's avatar
        michaelkenward
        It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
        The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
