prflip157
Nov 24, 2020Aspirant
SSID Broadcast
SSID for 2Ghz stopped broadcasting. I have restarted, turned off/on "Enable broadcast" and applied, but cannot see SSID as available wireless option. Need this as many home devices cannot connect to 5Ghz.
What do the LEDs show?
- wcalifasProdigy
Is there a button on the outside of the gateway that let's you turn on or off the wifi? If so press it for 5 seconds and see if that changes it, if not press it for 10 seconds if it has that button.
- prflip157AspirantThere is a on off button at the back close to the coacts connection. I press that but that didn’t solve the issue.
- prflip157AspirantAll of the lights are lit.
- wcalifasProdigyThere should be a wifi button on off on top
