Ja666
Oct 30, 2016Tutor
Storage User setup & Network folders
Hi, I just got 'old/new' WNDR4700 Centria storage router and have question concernig users allowed to access the share(s). WNDR4700 allows to go into menu ADVANCED -> Storage -> User_Setup to add Us...
- Nov 28, 2016
I did not downgrade WNDR4700 firmware. But it looks I solved some problems with user account other than 'admin' and what is more, finally I can access router HDD shared directory with 'user name' (other than router 'admin') and 'user password'.
ElaineM
Oct 31, 2016NETGEAR Employee Retired
Hi Ja666
Welcome to the community!
Can you provide us a screenshot where you add the user and password?
Do you have the latest firmware installed?
- Ja666Oct 31, 2016Tutor
Before Apply button:
After Apply button:
- ElaineMNov 01, 2016NETGEAR Employee Retired
After clicking Apply it should clear out the textboxes and the checkboxes should default to All - no password.
Looks like a firmware problem. I suggest that you try to reflash the firmware of the router by downloading the latest firmware from the website and upload it once again.
After loading the firmware, do not forget to factory reset the router and then configure the settings manually.
Once done, configure the user and password then verify if you will have the same problem.
