Ja666
Oct 30, 2016Tutor
Storage User setup & Network folders
Hi, I just got 'old/new' WNDR4700 Centria storage router and have question concernig users allowed to access the share(s). WNDR4700 allows to go into menu ADVANCED -> Storage -> User_Setup to add Us...
- Nov 28, 2016
I did not downgrade WNDR4700 firmware. But it looks I solved some problems with user account other than 'admin' and what is more, finally I can access router HDD shared directory with 'user name' (other than router 'admin') and 'user password'.
ElaineM
Nov 08, 2016NETGEAR Employee Retired
Can you try to downgrade the firmware and see if it will give you the same result?
Kindly direct me to which list.
Ja666
Nov 28, 2016Tutor
- ElaineMNov 29, 2016NETGEAR Employee Retired
Thank you for the update!
Glad you were able to solve it.
