hondadude1981's avatar
Apr 29, 2026
Successor to WNDR 3800/4300 and 6300 WNDR?
Can anyone provide the current Netgear router models that are the successor units to
WNDR 3800/4300 and 6300 WNDR?  I am looking for the newest router successor models that also receive periodic security updates (hopefully automatically) from Netgear.  TIA
  • CrimpOn's avatar
    CrimpOn
    Netgear's home WiFi routers are here:
    https://www.netgear.com/home/wifi/routers/
    WiFi6 products are the obvious successor models, and are generally less costly than the subsequent WiFi7 models.
    A significant consideration is the speed of the Internet Service Provider connection. (ISP)  Newer (and more expensive) models support higher than gigabit connections.
    Another consideration is the sort of devices to be connected on the LAN.  Once again, lower cost products have only gigabit Ethernet connections, while the more expensive products allow for higher speed connections.
  • plemans's avatar
    What performance goals do you have with this device? Those are pretty ancient devices. Several generations behind.
    So what are you trying to achieve for usage and whats you're budget? And the size of the home?
    Pretty hard to recommend much when you're asking about devices that old to upgrade.
