jvbuttex
Nov 28, 2017Aspirant
Table and wireless printer not seeing main network
I have had the R6220 for some time, almost a year. I have multiple signals 1- main network 2- guest account 3 - 2.4 signal for others. My network consists of NAS box (hard wired), wireless printers, ...
- Nov 29, 2017
Hi jvbuttex,
1. What is the firmware version of the router?
2. Is your main network the 5GHz band? If it is, then not all wireless devices can detect the 5GHz band. Please check the device specification and make sure that they are dual band devices (can connect to both 2.4GHz and 5GHz).
Dexter
Community Team
DexterJB
Nov 29, 2017NETGEAR Moderator
Hi jvbuttex,
Dexter
Community Team
jvbuttex
Dec 03, 2017Aspirant
Hello Dexter... Sorry for late reply, I didnt get any email notificaiton of your reply. My router has V1.1.050_1.0.1 version running.
yes 5GHz is main network. I had the printer connectied without issue about 3months ago. It seems somethign changed... A buddy said it may have a black list running that will keep some devices from connecting. Is this true?
Im verifying the printer settings just to make sure... I know I did add this router recently...
- jvbuttexDec 04, 2017Aspirant
After a bit of searching on Canon webiste. I found it... the printer only supports 2.4Ghz... so I am confusing the connectivity issue with the old router. I will change the setup so that I can use the 2.4ghz for my main network. Thanks for pointing me in this direction.
