StephenCWLL's avatar
StephenCWLL
This firmware file is incorrect!
Whether I ask the router to download the firmware itself or if I upload the correct firmware file, I get the same "This firmware file is incorrect!" message. I'm currently on V1.0.1.88 and trying to get to V1.0.1.96.
What's the next best step?
  • Retired_Member's avatar
    Retired_Member
    Oct 16, 2016
    I guess you'll have to live with it or relace it.
    The WNR2200 has been EOL'ed. There is currently no replacement product.
    Retired_Member
    when you downloaded file did you extract it before trying to use it?  6,017KB is what I got after extracting it.
    • StephenCWLL's avatar
      StephenCWLL
      Yes, i unzipped it and pointed it at the .img file when it asks for the firmware file.
      • michaelkenward's avatar
        michaelkenward
        Tried a second download? That can fix some broken retrievals.
