CaptHastings's avatar
CaptHastings
Turning router on/off when wi-fi is not in use?
Hi all,
I'm a bit new to using a WiFi router, and I have a general question.  I would like to physically turn off the router when I'm not using WiFi, more to save electricity than anything else - I'm already leaving my cable modem on 24/7 as I have phone service with it.  I'd rather not leave the WiFI router on if it is not being used for WiFi (especially overnight).
Would I be able to do this without harming the router?
Cheers,
Mike T.
  • You won't save much electricity with something as "power light" as a modem, but you could do it.
    The old idea that switching things on and off reduced their life doesn't stand up.
    I would be more concerned that every time you turn it on it has to reconfigure itself and negotiate a link with the modem and the Internet. In theory it should be painless, but there have been too many questions here about routers that don't reconnect to make me confident that it will work every time.
  • michaelkenward's avatar
    michaelkenward
    • CaptHastings's avatar
      CaptHastings
      Hi Mike,
      Thanks for replying to my post.
      I appreciate the input.  I'll more than likely leave it on in that case.
      Cheers,
      Mike T.
