chaitanya92
Mar 01, 2016Aspirant
Unable to access my network after i reset my Router
HI, i have recently tried to reset my router to factory defaults and i have followed the procedure to reset after doing so my network says it is secured and i need to enter a password to access it which i doesn't know . unless i conect to the router i cant access the web portal to change the seetings of my router i have no idea to what to do somebody help me over this issue .
Regards.
- Retired_MemberMar 01, 2016
use defaults...... they are on router label
- Retired_Member
- chaitanya92Aspirant
N150 WIRELESS ROUTER WNR612v3
NETGEAR88
Hi , i think once we reset router everything changes to default i.e,wifi name as highlighted in attached pic and it's status to open instead of secured if i am wrong please correct me. For instance i have tried that default password as quoted on router.
Regards.
- Retired_Member
netgear88 is secured ....default WIFI settings are secure...only your router uses the default passphrase for wifi.
Log in and change router password if your worried about it.
