SueWei's avatar
SueWei
Unable to connect to AC1200/EX6120 WiFi extender
Hello All,<br><br>I have recently configured my extender as I have changed to a new router. The extender seems to indicate that it is connected to the router however none of my devices are able to connect to the extender with the same password as my router as advised on the instruction manual. Our devices keep showing incorrect passwords. I have seen someone posted the same problem and managed to solve it by connecting to web browser to access the WiFi extender network. how do I do that??? All it shows is you are not connected to WiFi extender network.
  • plemans's avatar
    did you set it up using wps or using the installation wizard?
    If you used wps, I'd recommend factory resetting the extender and reinstalling using the installation assistant.
    • SueWei's avatar
      SueWei
      Yes I have connected via wps. I have also reset the extender to factory setting before configuring. Sorry to ask but I have no idea how to install using installation assistant or web browser. How do I connect to the WiFi extender network when I can’t even get my device to connect to the extender?
