JeBo's avatar
JeBo
Unable to enable wireless
Dear forum users,
I have the problem that it won't let me enable the "Enable Wireless Router Radio" option for my WNDR3700v2, so i cannot use my WiFi :(
Am I missing an option, or is my router broken?
I've upgraded to the latest firmware and also tried a factory reset!
Hope someone can help me :)
  • Try a factory reset.  If that still doesn't work, try pushing the radio button one more time.  If that still fails, then the router may be toast.
  • Is the wireless light on the router illuminated?  If not, push the button for a few seconds to turn the radios on.
    • JeBo's avatar
      JeBo
      They are not, but the button on the device is not reacting and none of the options in the admin panel of the router is responding when i try to turn it on.
