eagetal96's avatar
eagetal96
Upgraded Internet Speed and Netgear600 router won't support it....I think.
I have a surfboard SB6183 Modem and the N600 router. I previously had comast blast 75/10 and was getting these speeds hardwired with my imac. I upgraded to 150/25 and the speeds went to 90/22. When wired directly into the modem I am getting 175/25. I am no computer wiz but from my research I have found my wan port is set at 100m/full and it seems it needs to be at 1000m/full. I cannot figure out how to change this, any help is greatly appreciated!
  • michaelkenward's avatar
    michaelkenward
    Which N600 are you talking about? That is not a Netgear model number.
    Here's a clue on where to look:
    model number
    If it is a really old box, then the LAN ports will be 100 Mbps. Newer models are 1000Mbps.
    If it is a 100 Mbps router, such as the JNDR3000 and WNDR3400v2, then you are stuffed. There are no settings that you can tweak to make it go faster.
    • William10a's avatar
      William10a
      Master
      Almost any of new gigia port Netgear routers will work the r6400 of r7000 should just if the wndr3400v3 covered the with wifi. The my slow for now but keep it as you make a repeater or access point out of it to cover areas where not cover now.
        michaelkenward
        Hard to understand that. EFL?
