autigers1970
Nov 16, 2016Aspirant
USB attached storage with WNDR4500
I have a Netgear WNDR4500 that has two USB ports on the back for USB attached storage or printers. I have a new Seagate Expansion external USB hard drive I'd like to use with it to create network attached storage. I've formatted the drive (I'm on MacOS Sierra) but when I plug it in the USB light on the front doesn't turn on and I can't see the drive from the computer. Is there some trick to this I need to know? The documentation on this seems rather thin.
- Retired_MemberNov 16, 2016
Drive's require resources, Router USB resources are limited, compared to a USB port on a PC when the 4500 was designed YEARS ago the hard drives were 250Gb or less....now drives average 4tb and a router designed years ago Doesn't have the resources required to support larger drives.
- Retired_Member
Use this guide to see which drives are compatible, I checked and your Seagate Expansion isn't listed.
- autigers1970Aspirant
Wow, that is a short list of hard drives that will work. Don't understand why any USB hard drive, properly formatted, won't connect.
- Retired_Member
