HangingOut's avatar
HangingOut
Follower
Mar 25, 2024
Using R6350 - AC1750 router with a Hard Disk Drive to run the Logitech Media Server
Can I connect the Netgear R6350 - AC1750 to my current modem/router with an ethernet cable and use it with a USB attached Hard Disk Drive loaded with the Logitech Media Server to provide server support for my Logitect Squeezebox?  If yes, can someone tell me where to find detailed instructions on how to set it up?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Unlikely. The USB ports on the R6350 have two uses.You can plug in some "dumb" USB storage or you can add a printer to your network.
