Daniel272829
Oct 22, 2015Aspirant
WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2000v3 Please help
I scanned my MacBook with the avast antivirus and the network Scan a vulnerability which I was searching online to fix additional solution yet this is what I found on PCWorld website At first gl...
- Nov 10, 2015
Daniel272829 I would like to inform you that we have released the firmware that fixes SOAP vulnerability.
To upgrade, click here.
Thank you for you for being a loyal NETGEAR customer.
ElaineM
Nov 10, 2015NETGEAR Employee Retired
- applessNov 16, 2015Initiate
Is this firmware update going to make it to other routers? I have the same vunerabilty with wndr3700v2. Really need a firmware update ASAP.
- Daniel272829Nov 18, 2015Aspirant
Thanks for your reply i really appreciate it. but this update did not patch the vulnerability here is the latest status vulnerability check on a mac running IOS El Capitan 10.11.1 (15B42)
- ElaineMNov 19, 2015NETGEAR Employee Retired
Thank you for the screenshot.
Let me forward this to our engineering department and I will get back to you.
- ElaineMNov 24, 2015NETGEAR Employee Retired
Daniel272829 & jpurcielDo you guys have tried using a Windows PC?
Can you also verify if you get the same window shown below? The network should state no threats.
By the way, Daniel272829 make sure you have the latest firmware installed which is 1.1.2.12.
- jpurcielNov 30, 2015Aspirant
Also, I'm getting the Avast alerts on a Windows 10 Pro device. Thanks.
- ShaminaDec 25, 2015Aspirant
I am getting this message from AVAST too, I have DGN 1000v3, Router Firmware Version
V1.0.0.1_0.0.24, windows 10
