Daniel272829
Oct 22, 2015Aspirant
WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2000v3 Please help
I scanned my MacBook with the avast antivirus and the network Scan a vulnerability which I was searching online to fix additional solution yet this is what I found on PCWorld website At first gl...
- Nov 10, 2015
Daniel272829 I would like to inform you that we have released the firmware that fixes SOAP vulnerability.
To upgrade, click here.
Thank you for you for being a loyal NETGEAR customer.
Adrian_E
Dec 05, 2015Tutor
I have the same vulnerability picked up by Avast (v11.1.2245) on my WNDR3700v1 using windows 7 pro
Comes up as 'readyshare' and the ID code given in the title of this thread, which is how I came across it
My router is running firmware version 1.0.16.98 which I believe is the latest available (although I had to use the website to download and install this as the in-router update function didn't pick it up)
rwaldron
Dec 06, 2015Aspirant
I am getting the same exact same message for my Netgear with Avast Premium TM822A model Netgear router. Please inbox me via rebecca.waldron15@yahoo.com the way to update my Netgear. I love Netgear...I just want to be protected, thank you!
- ElaineMDec 07, 2015NETGEAR Employee Retired
Hi Everyone,
We would like let you all know that our engineers are still investigating on this reported issue.Kindly PM me your contact infos and please install teamviewer for further analysis.
rwaldron TM822A is the model of the modem. Can you verify at the bottom of the NETGEAR device the exact model of the router?
Thank you!
- KtucciDec 08, 2015Aspirant
I'm notcing all sorts of random spikes/problems i am having due to this issue. I believe its more then just a warning atleast for me for the past week i've notcied spikes while in any games, as well as disconnects from random things while maintaining internet, its quite wild actually I'm using the WNR2000 and i am recieving the same error. Please help as i believe this issue might be whats corresponding with my random spike problem even tho it shows me not loosing internet but when im playing games that require a little more bandwith then skype or teamspeak i can still talk and hear with no lag and listen to youtube but then i play a game and it will play perfectly fine then spike and some times disconnect me, and i have my resource monitor up and i dont see any thing or see my network utilization spike it'll stay at 0 even tho ill be lagging out of the games.
- Marcie1Dec 09, 2015Aspirant
I also am getting the same message; I am new to this community and new to joining online help in general, so I don't know if I'm making my inquiry the appropriate way. Is there an update or fix for this yet?
- Daniel272829Dec 10, 2015Aspirant
- ElaineMDec 10, 2015NETGEAR Employee Retired
Thank you for the info Daniel272829
Kindly check your inbox.
