Daniel272829
Oct 22, 2015Aspirant
WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2000v3 Please help
 I scanned my MacBook with the avast antivirus and the network Scan a vulnerability which I was searching online to fix additional solution yet this is what I found on PCWorld website      At first gl...
- Nov 10, 2015Daniel272829 I would like to inform you that we have released the firmware that fixes SOAP vulnerability. To upgrade, click here. Thank you for you for being a loyal NETGEAR customer.
mediatrek
Jan 07, 2016Virtuoso
The WNR1000v2 is an EOL (end of life) product. Netgear 99% of the time does not release new/patched firmware for EOL products even if there are known security holes (vulnerabilities). Basically Netgear wants you do go buy a new router to eliminate the security vulnerability. In other words; do not hold your breath for patched firmware.
Adrian_E
Jan 08, 2016Tutor
I've got the v1 version and have had it confirmed that due to it being 'EOL' there will be no new firmware. Seems a bit cheeky that a vulnerability built in to the device isn't seen as sufficient reason to offer a new firmware version if significant numbers of customers are asking for it.
Since it appears a new device is the only way to address the vulerability I'll be off to buy a product made by someone else, on principle. They'll probably prove just as bad at some point in the future, but I detest the attitude that results in a perfectly functional device ending up in the bin.
