Daniel272829
Oct 22, 2015Aspirant
WARNING Vulnerability ID: NON-2015-0211 on my Netgear Router WNR2000v3 Please help
 I scanned my MacBook with the avast antivirus and the network Scan a vulnerability which I was searching online to fix additional solution yet this is what I found on PCWorld website      At first gl...
- Nov 10, 2015Daniel272829 I would like to inform you that we have released the firmware that fixes SOAP vulnerability. To upgrade, click here. Thank you for you for being a loyal NETGEAR customer.
Patom
Jul 18, 2017Aspirant
I ran a check on AVAST and it came back with vulnerability warnings.The resolution said to upgrade my firmware software but I have the latest so that is no help. If one of you know what to do I would appreciate it very much.
- ElaineMJul 19, 2017NETGEAR Employee RetiredPatom I suggest that you report it at https://bugcrowd.com/netgear. - PatomJul 19, 2017AspirantI tried the link and could not find a place to report my problem. I am not loking to report I am looking to fix my problem. Patom - ElaineMJul 19, 2017NETGEAR Employee RetiredFirmware should have been the fix. If not, you may also try to contact Avast for the exact error message you're getting. Do they have any recommendation aside from firmware update? By the way, what's the exact model number of your router?
