Ping32's avatar
Ping32
What is a TA number?
I have a Netgear product that has several different numbers printed on the bottom of the box: TA, S/N, MAC.
I know MAC stands for Media Access Control, S/N stands for Serial Number. But what does "TA" stand for?
These TA numbers have been mentioned more than once for the past 10 years in various Netgear discussions across the web. But I am probably the first person to ask the question, the right question, what is this... TA?
  • So I got info on TA, it's a internal total assembly part number that NG used to use. Not used or printed anymore. Nothing that users can use or be aware of.
  • Any news on this? No? So no one knows? I got an email notification today (with a broken link) saying "Check it out! Your topic recently received a reply!" But that was just a reference to my own reply I guess. It's so silly, it came 7 days after the fact.
    So for the last time, what the AG, BG, CG is the freaking TA on the NG? You have the model number(s) now, can you answer the question now? The only thing I hate less than LED indicators that are not documented are acronyms that are uncommon and undocumented.
    • FURRYe38's avatar
      Wonder if that could stand for Transmitter Address?
      • Ping32's avatar
        Ping32
        I have written a new reply. Where is it? It appears to have been queued for approval and it has then been approved but I don't see it in this topic. I will post it again.
        What would something like that look like? What's the format? Would it be the same as for a MAC address? Something like A0:B1:C2:D3:E4:F5? This TA number looks something like 123-45678-90A1. That's 12 characters, just like a MAC address, but with very different separators (and in all the wrong places).
