Harshparker's avatar
Harshparker
What is the difference between a really expensive router (ex. Netgear nighthawk) vs some cheap
While not always a case, the basic rule of thumb is that the more money you put in your router, the more devices you can have connected simultaneously without noticing slowdown. More expensive router...
  • TaterSalid's avatar
    Oct 24, 2018
    Agreed. The WNR3500Lv2 and R6020 are good routers and cheap. These days you pay the big money for faster WiFi. The 3500 also has Gbit Ethernet.
