josephg304
Jan 08, 2021Tutor
Where do I find Firmware Updates for the RBK50V2
I am searchiung for any firmware updates for my RBK50V2 WiFi router. I can only find firmware updates for routers with the RBR and RBS model numbers.
When I try to uplopad this firmware pdate for the RBR model to my router, it tells me that the firmware update is the incorrect file.
Where can I find the correct firmware update file for my RBK50V2 router? (A direct link to the proper web page would be very much appreciated).
Thank you.
josephg304 wrote:I am searchiung for any firmware updates for my RBK50V2 WiFi router. I can only find firmware updates for routers with the RBR and RBS model numbers.
RBK does designate a kit including one RBR router and one (or more) RBS satellite.
josephg304 wrote:When I try to uplopad this firmware pdate for the RBR model to my router, it tells me that the firmware update is the incorrect file.
Open and unpack the zip archive - only the respective img file can be uploaded. plemans referred to the correct firmware kits above.
for the satellites: https://www.netgear.com/support/product/RBS50v2.aspx
for the router: https://www.netgear.com/support/product/RBr50v2.aspx
make suer to update the satellites first
Thank you. Much appreciated.
