edmark's avatar
edmark
Wifi connected but remote computer doesn't access internet
Wifi shows connected and computer shows on the network map, but my remote, wireless computer cannot access the internet, How can I fix it?
  • edmark's avatar
    edmark
    Apr 12, 2018
    Thanks for your advice. I got into my wife's network settings, they asked for my security password and then it connected to the Wifi network. Thanks so much for your help.
  • michaelkenward's avatar
    michaelkenward
    edmark wrote:
    ...my remote, wireless computer cannot access the internet
    Where is this "remote" computer? Same wifi network or somewhere else?
    What are you using to connect to the Netgear device?
    What Netgear hardware are we talking about?
    Apologies for piling on the questions.
    You can help people to help you by providing the information suggested in this forum's header:
        Subject (Include model number and brief summary)
        Model (Recommended - Helps the community give the best answers)
        Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    • edmark's avatar
      edmark
      Michael, thanks for responding. My "remote" computer is on the 2nd floor of my house, in my wife's office. My computer is downstairs. I only have the the new Wifi network. I have connected(wired) my new R6220 router a to a Cox modem a which provides my internet access. The new router is to provide Wifi to my wife's computer. The network map shows my wife's computer and the Wifi connerction status is connected, but my wife's computer cannot connect to the internet. can you help?
        michaelkenward
        OK. I asked because "remote" has a special meaning in network talk. It refers to getting into your network from the other side of the planet, for example, not from within the same local network. There are various settings for that in routers, but we can ignore that.
        In this case your wife has a problem connecting to the local wifi network.
        If her computer is running Windows, she may have to look at the network settings there. One common problem is that her PC thinks it is on a "public" network.
        What happens when she tries to establish a wifi connection? Have you tried using the Network Troubleshooter in Windows?
        We still don't have much information to go on. For example, we don't know if anything can connect to the wifi network. Do you have smartphones or tablets that connect happily to the router?
        We need to know that to confirm that your wifi network is set up properly and that the problem is at the client end, your wife's PC.
