ShreeRP's avatar
ShreeRP
wifi connectivity disconnects intermediatly
we are facing wifi disconnecting itermediatly and get dificulties to reconnect ... and afts er restart whole network devices the it connects again
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello ShreeRP,
    Welcome to the community!
    I'd like to know the model number of the device you are having issues with.
    Thanks,
    • JohnRo's avatar
      JohnRo
      Hi ShreeRP,
      We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      Thanks,
