gdavidbird
Mar 14, 2017Aspirant
Wifi IP cameras connected to router
I currently have 2 IP cameras (2.4 ghz) setup on a WNR2000 V5. Unfortunately, due to obstructions, I'm not getting a signal solid enough to change settings on the cams. The router is located adjacent...
- Mar 16, 2017
gdavidbird wrote:
Can I use an extender, like the WN3000RP, at the intermediate location to receive the cam signals that would then transmit to the existing router. If so, how would the settings work?
Yes, I said that earlier.
The extender will use a different network name from the main router. So you will either need to
- change the IP camera settings to connect to the new network name,
- change the router's network name, and then configure the extender's network name to match the router.
I described the second option above.
Mar 14, 2017Guru - Experienced User
Your router manual is here: http://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_UM_20Nov2014.pdf?cid=wmt_netgear_organic
I see AP mode, but I am not seeing a repeater mode. Bridge mode isn't there either (and wouldn't do what you want, since WiFi is used as the bridge).
If you can get ethernet to the intermediate location, you can move the router.
Other options:
- Use a powerline extender pair like the PLPW1000. Connect the non-wifi component to the router, and plug the other one in at the intermediate location.
- Install a wifi extender at the intermediate location
If you use an extender, you can record the network name, passphrase, and security mode of the WNR2000 wifi, and then change the network name. You can do the same with the PLPW1000 if you like, but it probably isn't necessary.
Then set up the extender or PLPW1000 to match the original settings on the WNR2000, so the cameras will connect to the new wifi signal.
- gdavidbirdMar 14, 2017Aspirant
- StephenBMar 16, 2017Guru - Experienced User
