cderrington
Oct 25, 2017Tutor
WiFi set up Recommendations with three R6300v2's
Hi Folks,
My buddy bought and I'm setting up three R6300v2 routers at his nightclub to replace two OLD WiFi routers. He bought the R6300v2 so he could use the Facebook WiFi "check-in thingy".
I'm looking for advice to see if I should set them up as one Router (providing WiFi too) and two AP's, or should I setup each R6300v2 as its own router (so there are actually three networks).
As I see it the one router and two AP's make sense so all devices are on one network, but we're limited to about 200 clients(heck, I'm not sure the R6300v2 can handle 200 clients)
If I go with three networks, can they all have the same SSID? I don't think I should use the same SSID for the 2.4GHz and 5Ghz, but I'm hoping that I can have three that say "BAR-NAME-2.4GHZ" and three that say "BAR-NAME-5GHZ"
Will fast roaming work if I set up three networks?
Should the DHCP ranges all be the same? I assume that the IP ranges should be different but I'm not sure.
Thanks for any input you can provide,
cderrington wrote:
Do you know what settings I should turn off to put the least amount of stress on the CPU and RAM of the "main" router?
I've never seen any suggestion here that this is an issue with this sort of hardware.
You may be creating a problem for yourself that doesn't exist.
Suck it and see is my advice.
That is probably the least troublesome route. Or you could end up with three routers fighting to control the local network.
There is a manual for the R6300v2 somewhere at the end of this link::
>>> R6300v2 | Product | Support | NETGEAR <<<
See page 100.
Thanks for the great answer!
I'm assuming that making sure traffic monitoring is not on will help and turning off UPNP but I'm not sure and don't know what other settings tax the processor and RAM. I tried calling support but they were clueless.- michaelkenwardGuru - Experienced User
